High temperature ceramic coatings
Does anyone have any advice or recommendations on ceramic coating parts, and specifically turbos?
Ant
Ant
Ant,
See my recent post in 'Performance Links' for the genuine article from Zircotec, one being trial fitted here with experimental insulating gasket from Ferriday Engineering (also recommended):
Turbo and exhaust elbow not coated as they are able to be wrapped and probably being changed in the future.
Ceramic paint (not as effective but a little cheaper and can be 'diy') is available from various outlets, made by:
http://www.camcoat.u-net.com
I believe these are the only two options in the UK at this time.
Martin.
Martin.
This is a little bit of text I picked up off the website in the link section..
[quote=Zircotec"]If exhaust gases exiting the combustion chamber are allowed to cool too fast they lose velocity, the ''scavenging effect'' is reduced and power lost.[/quote]
This is of particular importance to turbo'd applications as the heat & speed of the gases has a direct reflection on the performance of the unit itself.
Thats my understanding of its benefit anyway.
I would very much like to get a manifold on my car, dyno it and then do it again with the coating to see what performance increases have been made, if any. I do believe they would be seen easier on a high end turbo application.
Sorry for the quicky, but heat = energy so keep it in and use it! I think it's only marginal (SS isn't a good conductor either) and isn't my main reason for using it and no, I haven't heard of anyone who has tried a before and after test as yet, but every little helps, of course it is the sum of all the little mods which make the difference.
The other advantage of heat retention is of course to keep the engine bay cooler and to stop anything close to the mani' from melting, a problem with modified 'grales and plastic rad' fans. I've got a lovely pic somewhere of an integrale on the rollers with the manifold glowing cherry red......
Martin.
Martin.
Read:
http://guy-croft.com/viewtopic.php?t=429
Don't discuss prices here. If the firm you are referring to fits the posting/vendors criteria, fine. Otherwise not.
Speak to the company involved carefully about coatings on the inside of a turbo manifold, as far as I am aware they can't get around the bends with the coating and it is to be avoided as it can peel off and go through the turbo.
As I said, speak to the persons doing the work to confirm or otherwise.
Users browsing this forum: No registered users and 121 guests
