Anyone recognise this apparent Fiat crank/vr sensor
The code I can make out is 022 06K.
I'm trying to get the pin layout for it, for a new ecu loom.
205 8v Track car
Re: Anyone recognise this apparent Fiat crank/vr sensor
Magnei Marelli used by a lot of after market kits as well, Is it two wire or three wire? ( Third wire is for screening )
Darrian T90
ah, it's 3, i'm desperate for the correct pin layout. No pin reference numbers on it..aargh!
205 8v Track car
Just sent you a PM with link.
Pin 1 Return
Pin 2 Signal
Pin 3 Screen
Pin 1 Return
Pin 2 Signal
Pin 3 Screen
Darrian T90
you legend! Thanks ever so much! Even get to know the correct air gap which I believe was too wide previously
Sean
Sean
205 8v Track car
Such sensors can be bought easily for Fiat Cinquecento 700 for only about 10 pounds instead paying about 40-50 pounds for the same sensor for example for Intergrale. For Cinquecento it has only 2 wires but i never had any problems with it. The other difference may be the length of the cable(easy to fix).
The manufacturer is of course Magneti Marelli.
Book#378
Users browsing this forum: No registered users and 156 guests
