Page 5 of 7
Re: 1983 Pininfarina Europa Spider
Posted: April 6th, 2016, 7:03 pm
You may have torsional vibration problems with this setup.
Very unwise to use a universal joint at the drive end.
Posted: April 8th, 2016, 5:19 pm
by Marek
Dear Guy,
Thank you very much for your suggestion.
All my mistakes and faults I repaired during the next winter.
Posted: May 1st, 2016, 5:04 pm
by Piotrek125p
What up with progress with your 124 dear Marek ?
I'm sorry that I do not answer the last phone, I had a really lot of work last month, I will call you after holidays.
Posted: May 28th, 2016, 8:00 pm
by Marek
Posted: May 28th, 2016, 8:53 pm
by Spider 1969
Wow, beautiful exhaust. That's a tight fit! Is the header 4-1 or 4-2-1?
Posted: May 29th, 2016, 8:58 am
by Marek
Thank you very much.
Very little space. It is 4-1.
- IMG_3772 (Copy).JPG (42.92 KiB) Viewed 52041 times
- IMG_3766 (Copy).JPG (38.44 KiB) Viewed 52041 times
Posted: May 29th, 2016, 4:47 pm
Well done!
This is a careful & thoughtful job by your supplier Marek, done as close as possible to GC design regime. Not easy no. I suggested 4-1. A 4-2-1 manifold to a modern design (ie: optimal, to my spec) is almost impossible in the 124 ...
I like the care they have taken with the flexible joint and the nice suspension of the rear silencer. I can see they have done some nice cosmetic work too, polishing to make it look nice.
The pipe bends look good too, I would say they are all to GC spec ie: bend chord radius = 2 x pipe inner diameter.
A manifold like this generates a huge amount of heat in the engine bay, it can destroy your distributor! I would strongly advise you examine some thermal coating like the Zircotec we use here.
Tuning the 124 Coupe and Spider explores the LIMITS of what is possible in the restricted architecture of the engine bay. No room for anything!
Posted: May 30th, 2016, 7:25 am
by PumaPhil
Hi Marek,
I'd like to echo GC's comments, a beautifully executed exhaust that looks most professional. But please note, I had big problems with high under-bonnet temperatures but Zircotec coating really helped. It's not cheap but worth the investment for such a good system.
Several people advise me not to use exhaust wrap. The main reasons seem to be that wraps hold moisture and they create too much thermal boundary between the flange by the exhaust ports and the start of the downpipes.
You must be very pleased with the result.
Regards, PG
Posted: June 1st, 2016, 11:06 am
by Marek
Hello Phil,
Thank you very much for your next tip. Reffering to your's suggestions my exhaust manifold will be coated in company
http://www.hipeco.com/eng/
I hope I will be able to present the results very soon.
Posted: June 13th, 2016, 8:06 pm
by Marek
Referring to your tips and advice exhaust manifold has been coated thermal coating.
- IMG_3404 (Copy).JPG (25.1 KiB) Viewed 51927 times
- IMG_3403 (Copy).JPG (30.35 KiB) Viewed 51927 times
Posted: June 13th, 2016, 8:14 pm
looks good dear Marek..
if your supplier could do that again they would sell a LOT of them..
think about it..
Posted: June 13th, 2016, 8:19 pm
by Piotrek125p
I am very curious about thermal barrier that should ensure this coating,if it will works as well as it looks I am confident about results dear Marek.
Posted: June 13th, 2016, 8:22 pm
Marek is real careful professional guy, I bet it will be good...
Posted: July 24th, 2016, 8:50 pm
by PumaPhil
That is a fantastic looking manifold Marek, great stuff!
Posted: August 22nd, 2016, 1:42 pm
by Marek
Last week I started the engine. Therefore I was adjusting the carburetor first time I had some issues and trouble with lack of combustion on the first cylinder. Herein I would like to thank Guy for his support. During the interview Guy quickly realized what's the matter and a few short and concise guidance from Guy was enough to run the engine properly.
PS. Guy, alluding to my preliminary actions with start of 'your's' engine, remember that you aren't first on the list to catch me.
