Hi all,
I just wanted to post up my new exhaust manifold and turbo set up pictures what I have just had made, once again I was involved with the build from start to finish but did not make it. The turbo is a Garrett GT3071R with Tial exhaust housing and Tial 38mm wastegate all on V band set up, this makes it so easy to take off and upgrade exhuast housing if desired. The Tial exhaust housings are made from lightweight stainless steel and as smooth as a babies bottom on the inside, I have also had a 38mm screamer pipe fitted for the maximum pop, bang and flame effect which comes out just under the front bumper, this all fits behind the standard radiator with a 12" super slimline fan.
Your comments welcome.
Lancia Delta HF Integrale Exhaust Manifold & Turbo
- 001.JPG (57.89 KiB) Viewed 4124 times
- 002.JPG (49.1 KiB) Viewed 4124 times
- 003.JPG (59.33 KiB) Viewed 4124 times
- 004.JPG (23.78 KiB) Viewed 4124 times
- 005.JPG (31.56 KiB) Viewed 4124 times
- 006.JPG (31.43 KiB) Viewed 4124 times
- 007.JPG (34.03 KiB) Viewed 4124 times
Users browsing this forum: No registered users and 134 guests
