Darrian T90 owned by Colin Haggett
This is my Darrian T90, It was purchased or built in 1995 from Tim duffee of Darrian Cars in Llangybi, Wales.
- Darrian T90 at a wet Longcross
- Darrian T90 at Longcross.jpg (174.39 KiB) Viewed 7153 times
Darrian T90
Darrian T90 at Tim Dufee's workshop
When first built it was fitted with a Guy Croft 8 Valve engine similar to case history No 5 in Guy's brillant Workshop manual using Weber Alpha fuel injection and four direct coils. This was mated to a Hewland mk9 five speed transaxle.
- Bare tub of my Darrian T90 showing how the car is built around the rollcage.
- Tub 1.jpg (101.92 KiB) Viewed 7149 times
- As you can see Guy Croft engine fitted to Hewland 5 speed transaxle. Plus you can see Stack dash unit.
- Darrian Cars workshop 1.jpg (219.27 KiB) Viewed 7150 times
Darrian T90
Darrian T90 with 16 valve engine fitted.
Some more Photos of my Darrian T90. The spec has changed a lot, Now fitted with 16 valve engine which is dry sumped and mated to Hewland FGC 5 speed transaxle.
- Inside photo showing Sack display and quick release steering wheel.
- Inside small.jpg (25.65 KiB) Viewed 7143 times
- Engine bay with 16 valve engine still fitted with Weber Alpha injection.
- Engine.jpg (43.68 KiB) Viewed 7145 times
Darrian T90
Darrian T90 Engine photos
Some engine photos
- New dry sump tank from A.H.Fabrications. Fixed problem of oil being pumped into catch tank on long stages.
- Darrian engine.jpg (37.64 KiB) Viewed 7131 times
- Engine with Hewland gearbox in the background.
- Engine out.jpg (30.46 KiB) Viewed 7132 times
- Engine out showing Guy Croft light weight flywheel fitted with AP twin plate paddle clutch. Also you will notice I have moved the coil pack away from the exhaust.
- Engine 2.jpg (31.13 KiB) Viewed 7134 times
Darrian T90
Users browsing this forum: No registered users and 236 guests
