Hi looking for camchafts for my Fiat X1/9 Abarth Replica . The set up is DTA e48 ECU about 11-1 in compression 40mm throttlebodies ,( will fit 45 soon)4 to 1 headers comming soon, The head is slightly modified after MR, Croft book,
If i had good std cams MR ,Croft had the possibilety to grind camms for mee . But i have not.
My brand new german bilett camms givs good torque ,but dont suit my needs, They are Intake280 deg.10,9 lift, Lift at TDC 1,6mm Outlet 256 dedeg 9,6 in lift , Lift at TDC 1,3mm.
Dont know if these specks are with or wihtout clarance. But feels almost the same as OE cams, Gives a little more torque , After my meening to little duration.
The cams i choose must also bee lowcost , and i need somthing like medium race , Or at least so i can have a spinn on the roads too.Any good hints out there ? Regards Ove Thorkildsen Oslo Norway-
othorkild@c2i.net
Need Camchafts for my 2,0 16v engine.used in my X1/9
Re: Need Camchafts for my 2,0 16v engine.used in my X1/9
engine has a 16v Tipo/Integrale type head in case anyone is wondering what cams are needed here..
they look like steel cams - you can't reprofile them
Hi Ove
can you contact Daniel and pay his mailing on the cams please?
I will get them ground to L1/BD3 in April.
Sincerely,
Sincerely,
Users browsing this forum: No registered users and 125 guests
