Full lift timing method.
4v6
Post by 4v6 » June 1st, 2018, 6:22 pm
Hello all, bit of a daft question probably but I cannot seem to find an answer anywhere regarding it.
As I understand it, the full lift timing method consists of adding together the first two figures on your cam iming information card, such as 25 65 65 25, and then adding 180 degrees of crank rotation to give duration.
In the example above you would have 270 degrees of duration, and to find full lift position you would divide that by two then subtract the first number (inlet opening) to give the number of crank degrees (135) minus 25 = 110 atdc...if Ive got that right.
The question regards the subrtaction of that first number. Why?
Surely full lift would be half the duration?
What am I missing?
I have sent an email to a cam company but had nothing back hence posting it here.
Any help gratefully appreciated to satisfy my addled brain.
Tony Warren. GC #96.
Re: Full lift timing method.
Post by TomLouwrier » June 2nd, 2018, 9:20 am
Hi Tony,
You are right that full lift happens at half the duration. That is: in cam degrees.
But since the lifting starts at 25' btdc crank degrees, the cam degrees have a 25' offset (which is cam timing by definition...).
So when you subtract the 25' you place full lift (cam timing) correctly related to crank timing. And that gives you full lift in crank degrees.
thank you!
4v6
Post by 4v6 » June 2nd, 2018, 5:59 pm
Thanks for your help on that Tom, a lot clearer now!
Best wishes, Tony.
Post by Guy Croft » June 4th, 2018, 6:11 pm
subtracting the lowest number gives you FL relative to TDC for inlet and ex cams rather than just the geometric angular centreline. ..
4v6
Post by 4v6 » June 4th, 2018, 6:40 pm
Thank you Guy, now makes better sense to me.
Best wishes, Tony.
