Supercharger Partial Overhaul Question
Megaera
Post by Megaera » November 21st, 2017, 11:35 am
I have a Volumex unit - currently on a spare engine - which I would like to partially overhaul. “ Partial” as in replace the rear bearings and seals, clean the casing and rotors - as per GC instructions on this site, but leaving the rotors in place.
I have a high torque nut gun for removing the pulley nut - but my question is, without the correct Fiat tool, can anyone advise me on how to lock the pulley/rotors satisfactorily, in order to re-torque the pulley nut?
I have considered various options (tight fitting wood block in between the rotors and/or “universal” cam wheel locker by Sealey, or utilising an old cambelt wrapped around the pulley and clamped in a vice).
I would not be confident enough using any of these methods without prior confirmation that these are viable options......
I would be grateful if anyone who has done this job without the Fiat tool, could advise me on the method they used
GC_122
Re: Supercharger Partial Overhaul Question
Post by Guy Croft » November 21st, 2017, 5:51 pm
ideally it needs a Fiat camwheel-locking tool so you can lock the front pulley in a vice.
I forget the torque setting but have it at my works.
I don't know if Fiat still sell them, I have a part number if you call me one day after 12...
01522 705222
Megaera
Post by Megaera » November 22nd, 2017, 12:50 am
Thank you for your reply.
I shall definitely call you, as I also need to order the parts!
GC_122
Post by Guy Croft » November 22nd, 2017, 5:35 pm
that tool is not aval from Fiat!
"back-order, no date" my Fiat dealer tells me.
