hcd
Post
by hcd » October 10th, 2006, 8:52 am
Here's a simple weight distribution calculator I wrote to work out the optimum
layout for my racecar. Have a play, hope it's of some use to someone.
http://www.racingaspirations.com/weightdistribution.php
Huw
hcd on October 19th, 2006, 6:52 pm, edited 1 time in total.
Post
by Guy Croft » October 10th, 2006, 9:32 am
MODEL POST!
What a fantastic tool Huw! You are brilliant at these things!
I actually think you should hide it and be patenting it!
hcd
Post
by hcd » May 14th, 2013, 11:52 am
Wow! Has it really been that long since the original Weight Distribution Calculator. I've recently made change to add CoG and corner weights as well as jut plain making it better.
http://www.guy-croft.com is still a healthy referrer of traffic to my website so I'm hoping you guys will also appreciate this:
The new calculator offers the following enhancements over it's predecessor:
- More Workspace - 4.5 times more workspace than before to be precise.
- Sharing - As before, you can share a link back to your project but now you can also embed the results in your website or forum.
- Unlimited Objects - Not only is there now a ballast object but any number of objects can be added to your project so you can have two engines, two driven axles and four passengers if you wish.
- CoG and Corner Weights - They're displayed right there on the workspace.
- Selectable Plans - You now place your objects on a vehicle plan which you can change to represent your own vehicle.
- Room for Improvement - This is one of the new breed of calculators offered by racingaspirations.com with scope built in to enhance the functionality without needed to go back to the drawing board.
Click the link below to be directed to the
Weight Distribution Calculator loaded with some sample data.
I hope you find this calculator a useful addition to your toolkit and would like to remind you if you haven't already done so to
register yourself on the site.
Huw
Simon
Post
by Simon » May 14th, 2013, 1:10 pm
You have some great applications there Huw, very useful indeed! I've just registered.
GC_15
timinator
Post
by timinator » May 15th, 2013, 4:03 pm
Hi Huw,
Thank you for making your app available. It is a very valuable tool. I have registered also.
Have you looked at Hyperco's app for suspension spring rate and wheel rate calculator. They include spring angle and shock height from extended height in their calculator. Might be something of interest to you.
Post
by Guy Croft » May 20th, 2013, 5:37 pm
MODEL POST!
Very good to see you again Huw!! How the years fly....
Thanks very much for making this so kindly available to readers here,
sincerely,
hcd
Post
by hcd » May 22nd, 2013, 12:13 pm
Thanks Guy. Hopefully everyone will also benefit from these recent updates as well:
- Moment of inertia - The lateral and longitudinal moments of inertia are displayed within the calculator
- Right to left bias - This has been added within the calculator's bounds
- Front to rear bias - This has been added within the calculator's bounds
- Switchable analysis layers - The corner weights as well as any of the above can be switched between by pressing on the multi colored analysis bar at the top of the calculator
- More precise rounding - Better rounding of values at the correct places within the calculator code has resulted in far better precision
- More components - You can now add the wheels to represent unsprung weight and there is a special CoG object that allows you add the total weight of the vehicle before or after the components have been added
By way of example I've included links to the analysis of my car as it was at Brands Hatch:
Huw
Post
by Will01 » June 10th, 2013, 11:54 am
This looks like a great tool Huw, i will be checking out the site and joining.
Maybe it will come in handy for setup, although I will have to sort out my DIY scale setup for corner weighting before being able to use properly.
Nice one.
hcd
Post
by hcd » June 11th, 2013, 7:54 am
Thanks Will and thanks for joining.
Huw
