BMW E30 rear suspension for 131
Posted: April 3rd, 2013, 2:39 pm
by Ab131
Hi.
I am taking over a abarth replica project.
And i plan to make indipendent rear suspension from bmw e30.
Has anyone done this before? Tips. Pictures. Anything would be healpfull..!
Harry.
Re: BMW E30 rear suspension for 131
Posted: April 5th, 2013, 9:35 pm
by miro-1980
Harry,
Contact Walezy of this forum. He has all the best experience with e-30 diff for a 131 and I am sure he has plenty of pictures.
If you have problems obtaining him - let me know and I will put you in touch.
Posted: April 6th, 2013, 12:33 pm
by Ab131
Ok.
I will send him a mail. I think i got his mail adress from when i bought a abarth tarmac kit for my 131.
Harry.
Posted: April 10th, 2013, 9:11 am
by Walezy
I will give you a reply today about it.
I have fitted custom made suspension in my Fiat that is based on original design but it is not a copy of original abarth suspension.
Posted: April 28th, 2013, 5:09 am
by Kovacevic
Harry,
If you haven't already started on this conversion, you may want to think about other alternatives. I looked at an E 30 rear end for my Abarth replica, but the down side is that there are not a great choice of ratios, and they are basically a single arm. I ended up using the rear end out of a Nissan S15 (maybe delivered in your country as a Sylvia or 200SX), cheap to purchase, double A arm design, and is mounted in a cradle - all that was required was to fit and reinforce 4 mounting studs, and to open up the shocker towers a little at the base. I elected to narrow the rear end by 100mm to retain the same track as original, but you could leave it as is if you wanted. I had to have one driveshaft made, and the short shaft became the long shaft - the Nissan R200 diff is bulletproof, and comes standard with a torsen type LSD.
Just a thought,
Alex
