Fiat X19 Oil Pump Drive Gear
Posted: June 10th, 2015, 9:04 am
Reference: Fiat X19 1500cc Engine and the Oil Feed to the Skew Gear Bush.
On the front Auxiliary Shaft bearing there is an Oil Hole that seems to go the Bronze Bush.
However it does not line up the Hole that the Bush has.
In fact the Hole in the Bush actually faces towards the outside of the engine.
I think the engine is original and has never been touched.
Although the Bush is slightly worn it must have been getting its Oil from the excess around that area.
It just seems strange that a Feed Hole is in place and not used unless it was required for an earlier version of engine.
Many Thanks
Alistair
Many Thanks
Alistair
