Engine bearing clearance
pete_rallye
Post by pete_rallye »
Hi, I am just choosing some engine bearings for a Peugeot XU race engine that I am building and have a question! The bearings are available in the usual standard and associated oversize, but also in an additional size of an extra thou vertical oil clearance. I was just wondering under what circumstances you would use such bearings? Thanks.
Book No. 373 for me!
Re: Engine bearing clearance
You should use the bearing that gives minimum clearance but yet still allows the crank assy to turn freely. There is no virtue at all to running wide clearances - it just increases the oil bleed-down.
pete_rallye
Thanks Guy, I couldn't work out why you would want more clearance!
Users browsing this forum: No registered users and 122 guests
