here are two engine cylinder head gasket for TC engines, one original and one I do not really know. The first seal is missing a hole on the water pump side, and smaller holes on the opposite side as you can see from the pictures.
Is it advisable to use this first seal?
Daniel
Cylinder head gasket comparison
- IMG_0368.jpg (74.98 KiB) Viewed 5010 times
- IMG_0373.jpg (136.79 KiB) Viewed 5010 times
GC_17
Re: Cylinder head gasket comparison
The top gasket is strictly for a reversed port unit. You can see that the coolant holes are (if offered up to the 8v 131 type head) in the wrong orientation - the larger holes should be on the ex side.
Don't know about the lower gasket can I have a photo of the whole thing?
Thank you very much for your help.
I only wanted to know if this first head gasket could be useful to the 130TC. That is not the case!
The lower have to be a stock one, with a thickness of about 2 mm and a bore of 85mm.
Many thanks for the look
Daniel
Daniel
- IMG_0382.jpg (116.43 KiB) Viewed 4976 times
- IMG_0384.jpg (112.61 KiB) Viewed 4976 times
- IMG_0390.jpg (85.19 KiB) Viewed 4976 times
GC_17
yes the latest one you have shown is right, 130TC late generation OE
Users browsing this forum: No registered users and 64 guests
