Page 1 of 2
Peugeot 205 GTi big end bearings replacement
Posted: February 18th, 2011, 4:13 pm
by DamirGTI
Hi Guy !
Please , i need your help with this :
I'm in the process of "freshening up" my engine , up to the point now to replacing big end bearing shells - how to prepare them (clean protective coating) prior to fitting ? and is there any special precautions during the torquing up the conrod bolts (i'm reusing old conrod bolts , but will mix them up a bit from one to another rod and apply Loctite thread sealant .. hope that's fine ..)
As for torque stages for the big end bearing bolts/nuts , the OE spec. goes like this :
1. 40 Nm
2. Slack off
3. 20 Nm + 70 deg.
.. now , the thing that's worries me is - i do not have a degree wheel for the angle torquing , can this " +70 deg. " be re-calculated in Nm-s instead of degrees ?
Something else i need to watch out during this procedure of bearing shells replacement ?
Thanks !!
Kind regards
Damir
Re: Peugeot 205 GTi big end bearings replacement
Posted: February 18th, 2011, 5:24 pm
NO LOCTITE.
use engine oil as the lubricant on threads and bolt or nut underhead.
If you tell me the exact bolt thread diameter I will give a torque setting tomorrow.
Posted: February 19th, 2011, 12:23 am
by DamirGTI
Ok. Guy , it's not urgent , will measure bolt thread diameter tomorrow and post the measurements .. as well as a few pictures of the piston/conrod/bolt+nut assembly . (just got back from the garage , and off to sleep - exhausted !!)
Thanks !
Kind regards
Damir
Posted: February 19th, 2011, 7:53 pm
by DamirGTI
Hi !
As requested , heres the conrod bolt thread dia. :
Conrod bolt thread : 9.00mm
Some pics :
Piston assembly
Conrod
Conrod bolt thread
Conrod nut (with some slotted markings -> I and II .. dunno what they represent ?!)
Conrod bolt and nut
Conrod bolt thread dia.
Conrod nut dia.
Now , the bearing shells ... they've done about 60.000km's now :
Piston No.1
Piston No.2
Piston No.3
Piston No.4
... one shot of the main bearing shell (flywheel end of the crankshaft) :
And some crankshaft seal dilemma , the OE seal has some sort of ribs and arrow on it , while aftermarket one doesent have a ribs nor the arrow ... so , dunno if it's wise to fit this aftermarket one or refit back the OE seal ? they're same dimension - 90x110-7 .
OE seal (the black/brown on the top is an OE item , the bottom blue seal is aftermarket ..)
Thanks !!
Damir
Posted: February 20th, 2011, 3:43 pm
by DamirGTI
Found an more precise , OE conrod bolt spec. -> CONNEC ROD BOLT DIAM 9X100
Regards !
Damir
Posted: February 21st, 2011, 9:45 am
Tighten the nuts to 51Nm (38lbf ft). If they torque OK they should be alright although ordinarily I would use new. Be sure to use a highly accurate torque wrench like Facom or Snap-On, not soem cheap thing that will overtighten them.
The markings on the nuts are to indicate the grade of material.
As for the seal - if it's the right diameter and same type material (nitrile polymer), design - with sealing edge, spring and dust lip on the outside it is probably OK. I always use only OE seals - the consequences of a leak there are pretty dreadful!
Posted: February 21st, 2011, 7:18 pm
by DamirGTI
Understood , thanks for info Guy !
Just one more thing : which type of solvent do you normally use for cleaning up protective coating on the bearing shells ? ... is brake cleaner or cellulose thinner good for this ?!
Kind regards
Damir
Posted: February 22nd, 2011, 9:06 am
I would just use brake cleaner - presumably you can get hold of this? I use G Force/Wynns/Wurth..
Posted: February 22nd, 2011, 6:15 pm
by DamirGTI
Yes ! i do have Wurth brake cleaner ... (already waisted 4 cans for cleaning the block/head etc. !!)
Thanks for help/info !
Kind regards
Damir
... a few ones for the record :
Me and my night shift mechanic !
.. inspection in progress ...
(payment tomorrow , though , he doesn't accept cash nor credit cards -> just fishes !)
Posted: February 23rd, 2011, 10:16 am
Always nice to see the 'human touch' Damir!
Posted: February 28th, 2011, 11:20 am
by DamirGTI
Greetings Guy !
A quick one please , dunno if i'm doing something wrong here .
Big end bearing shell protective coat cleaning - they have some kind of white , not oily but more kinda "powdery" coating , tried to clean them with Wurth brake cleaner but seems like nothing happens ?! (no coating dissolving ...) , tried with cellulose thinner on a two shells for a test -> something started to happened , white appearance clears but again not completely ...
So , do they have to be bright shiny cleaned or not ?!?
The two ones on the left are cleaned first with brake cleaner , then with cellulose thinner , the rest of the shells on the right are just washed/sprayed with brake cleaner :
"The cleaned ones" - is this enough ?
Thanks !
Kind regards
Damir
(they're the Glyco bearing shells ...)
Posted: February 28th, 2011, 11:40 am
sorry to say but it sounds like oxidation to me...
I see it sometimes on the new generation Fiat bearings if moisture has got into the packet.
Posted: February 28th, 2011, 11:55 am
by DamirGTI
... so , what should i do now ?! i can't take them back for money refund .
The packet was vacuum sealed up all around (though there might been some pin hole on the PVC bag ...) , the ones which i've been using before where "AE" bearings (in the blue package .. this ones are Glyco , in the red package .. ) and they've had white/milky oily coating which was easy to remove ...
Damir
Posted: February 28th, 2011, 12:34 pm
sorry but it is entirely up to you, Damir...
No way would I personally fit them.
Posted: February 28th, 2011, 12:40 pm
by DamirGTI
Ok. , will try to replace/return them ... or get a money refund to buy a new ones .
Thanks for info !
Kind regards
Damir
