by robert kenney » Tue Jul 27, 2010 4:48 pm
Need to know what jetting you all are running on your DCOE 45s. Looking for only base line data as a starting point and to help diagnose a very rich condition. I attached a picture of the setup for reference. 5.2 liters, 10:1 compression, .475" lift and 230 I+E duration at @ .050 tappet lift, 1.5 ratio rocker arms, 110 LC. Fixed timing magneto dead timed at 25* for now. Carbs synced very close. Idle speed screws in from contact 1/2 (rough) turn.
Existing jetting
Mains: 145 (1.45mm drilled out? should measure)
Air correctors: 170
Idle jets: 40f6
Basically it will idle down well considering cam and idle screws like to be at between 1/4-1/2 turn out. Great throttle response off of idle. Seems ok on the pilots but as soon as it sees the main circuit it goes blowing black rich. The jetting seems close numericaly but you all can let me know if that is correct. From my form searches the range is wide as far as what people are running.
I have verified float levels at 8.5mm and fuel pressure is at 4 psi.fuel inlet valves close off well and it can hold the pump pressure with the engine off. Cold start valves are shutting off well.
- Texs T crop.JPG (55.3 KiB) Viewed 360 times
