Bacci gearsets, differentials, gearboxes..
Useful Links - posting strictly with GC permission only
Post by Guy Croft » Tue Nov 29, 2011 12:44 pm
http://www.bacciromano.com/index.php?p= ... 2=92&mar=4
great fun even if you can't afford any of it!
4v6
Re: Bacci gearsets, differentials, gearboxes..
Post by 4v6 » Thu Dec 08, 2011 11:00 am
Wow! They actually do a straight cut gearset and a limited slip differential for my quattro.
Pity it costs more than the car!
Still, nice stuff all the same.
Tony Warren. GC #96.
DeltaDave
Post by DeltaDave » Thu Dec 08, 2011 8:47 pm
I have noticed over the past few weeks there has been a massive price increase on the Bacci Romano website, the sequential gearbox for the Integrale 16v has risen from 13800 euros to 15698 euros. Probably due to the Eurozone problems.
Post by Guy Croft » Fri Dec 09, 2011 10:18 am
Quite possible.
I would say this regarding price - I would trade 40bhp on a 180bhp engine for a close-ratio gearset.
The difference compared with a production gearset (with very few exceptions) is like 'night and day'. Perhaps this outs the cost thing into perspective.
As for things costing 'more than the car' - this is invariably true.
Biancorally
Post by Biancorally » Sat Dec 10, 2011 1:40 pm
I'd like to share my opinion and experience on Bacci component. True, Bacci has a lot of gearing, but at that price quality and finish of the gears, do not go!
Some friends of me, who also race with Bacci internals their have all ended up broken. They failed before the end of the season.
I do not want to offend anyone, but at the price that all this cost I much preferred to buy something of better quality, even more expensive. The race is over once past the finish line and not halfway.
For me a good gearbox is paramount. No need to have an engine with 200 hp, if unreliable or if every time you change the engine speed, drops below the torque.
In my case I had some bad surprises rebuilding my gearbox with Bacci internals. I had to open the box 3 times to solve Bacci problem.
What's wrong?
Note the centering of the 5th speed fork, fully offset by tightening the fork to the rod. (the red line indicates the offset)
What's wrong?
the red line indicates a too short spacer ring,
note burrs remaining on dogs (black arrow)
the reverse gear of origin (Strada 130TC) was not compatible with the Bacci teeth, Strada 60 reverse gear required, not supplied with.
GC_17
Post by Guy Croft » Mon Dec 12, 2011 9:40 am
Did you raise these issues with them?
Biancorally
Post by Biancorally » Mon Dec 12, 2011 10:17 am
Yes, partially solved the problem with them.
After 3 phone calls I was able to solve the problem.
I must say they are very helpful.
I hope the gears are strong enough, apparently the weak point of its Bacci transmissions!
Daniel
GC_17
Post by Guy Croft » Tue Dec 13, 2011 9:50 am
You are expert with the things you do and have made some justifiable technical criticisms but in quite a constructive way and have been in touch with the company. All firms get things wrong from time to time but you did the right thing contacting them and I pleased to hear they were responsive.
If you had not done so I would have binned your post under Protocol 11.
Biancorally
Post by Biancorally » Tue Dec 13, 2011 11:57 am
I totally agree that from time to time there may be a fault.
I hope this will help others to be careful when reassembling a gearbox, and if you have any doubts disassembled and seek the cause.
Thank you Guy.
Daniel
GC_17
badlyworntoy
Post by badlyworntoy » Wed Apr 29, 2015 7:33 pm
First Time I've read this...... I too have a Bacci Romano Close ratio Gear-set for my 131 AB 5 speed gearbox. The quality/service/performance/reliability I cannot fault on that particular Gear-set. Yes their kits are typically less than half the Price of equivalent Colotti but I hear about those going wrong too.
Id sooner buy 3 Bacci sets than 1 Colotti.
