Fiat Twin Cam camshaft timing and fitting and dry build
Locked
GUY CROFT RACING ENGINES
Fiat/Lancia TWIN-CAM
Cam timing and fitting data and dry-build piston-valve checks
**** With a TC you should set the cams up with the head off ****
If you do it on the engine you will bend a valve for sure
General
Nominal cam lift can be measured by putting cam between revolving centres or on V blocks, and rotating cam with dial gauge on cam profile. Subtract clearance to give true lift in running conditions.
The base circle diameter many competition cams is less than std so thicker shims / top-hat shims or cam tower machining may be needed, though when the valve seats are blueprinted (ie: opened out) the valves go deeper into the head and this takes up some of the clearance - without resorting to massive shims. OE type shims thinner than 3.30mm must not be used or the cam nose will hit the bucket. Use new cam setting shims! Cam housings should be brush-honed at 180 grit silicon carbide or cleaned with fine Scotchbrite and then Jizer or Gunk or similar & detergent with hot water. New seals should be used. If you’re re-using old cams, polish the journals with fine Scotchbrite. If you are fitting head to a previously run block make sure there is no grit/muck from cleaning the block face in the 6 oil feeds in the block. Seal them off if scraping or rubbing down the block. Dirt in these galleries will go straight into the cam journals and seals on start up, causing scoring and seal damage. Head and block need to be flat in all directions to 3 thou or better. You can survey them with a good quality straight edge and a feeler gauge. After installing cams in their housing bolt the cam pulleys in place. Make sure the back of the pulleys does not foul the cambox or the seal, there is end float on the cams and the castings do vary in length. If the pulley is too close, get it machined on the back. Bolt each cambox to the head with new gasket and shim up close to the final setting. The gasket will settle 2 thou overnight, so when it has settled, slacken the cam box bolts fractionally and retorque before final shimming. You can do cam timing whether the head is shimmed up or not, but if the shims are tight, the cam may be hard to turn.
Never turn a TC cam unless you can see the valves especially on a big-valve conversion – the valves may clash and bend. If in doubt remove or slacken off one cam box.
Step 1 – establishing Full Lift (see also photos in rear of Kent Cams book if supplied)
There is a dwell phase around full lift of several degrees on most cams, to hold the valve open at full lift. A reground cam of same lift and duration as a billet cam will have a nose of much reduced volume and flow and a smaller dwell period. To begin with a protractor and dial gauge (with scale big enough to accommodate cam full lift) is needed to establish the centreline of the full lift position, as this will be the datum from which the cams are timed. The cam does not need to be shimmed accurately up to do this.
To establish full lift turn the cam with dial gauge on the valve to the max lift reading - then turn cam anti-clockwise till lift reads say, 9mm, or some other fixed point on the cam flank say 0.5mm lower than full lift. Make sure the cam does not rotate of its own accord. Then stick a large diameter protractor (you can get them from stationery shops) to the rim of the cam pulley with Blu-Tack, bolt a sharp-tipped pointer to the head and set the pointer to zero degrees. Then turn the cam the other way – clockwise, thru full lift and back down to the same point on the opposite cam flank and read the degrees. True full lift is halfway between 0 and this reading. Swing the cam to and fro and check that true full lift is exactly in the middle of the dwell phase.
Mark full lift on the rear cam journal relative to the housing, say with 2 scribed or pin-punch marks painted white – this gives you the FL reference point, which is useful if you want to check the cam timing later with the engine built and the belt on. The same method as determining the centreline of FL is used to determine true tdc on the crank – using a protractor on flywheel, a fixed pointer and a dti on no1 or 4 piston.
Make sure you bolt a tdc pointer rigidly to the block and aimed at the flywheel or front pulley - before you fit the head. Once the head is on you will struggle to find true tdc with accuracy otherwise.
Step 2 - Cam timing – how it’s done
Cams rotate at ½ crank speed. The engine rotates clockwise viewed from the crank front pulley end. TC cams are always set up on No.1 cylinder, with the valves on the overlap phase (inlet opening, exhaust closing) – not the compression stroke, although when no1 is on overlap, no 4 will be on compression (both valves closed).
The cam degree setting at tdc, relative to cam full lift, will be ½ the crank degrees at which you want full lift.
So if you want cam full lift (see below) at 110 crank degrees the inlet cam will need to be set at 55 cam degrees before cam full lift (no 1 lobe) at tdc and the exhaust 55 cam degrees after cam full lift.
EG: In the above example –
For the inlet cam turn the pulley anti-clockwise 55 cam degrees from full lift to put it before its full lift posn.
The exhaust cam should be rotated clockwise 55 cam degrees from full lift to put it after its full lift posn.
Mark the tdc posn with a red mark on the cam relative to the white mark on the housing.
The values full lift, timed-in degrees and lift at tdc with the cam shimmed up should always be recorded for dyno reference. You can check and adjust the cam timing on the engine – but only with the belt final fitted and ONLY if you have adjustable camwheels.
Step 3 – Dry-build
With non-standard cams I always recommend dry building and measuring the clearances using modelling clay in the valve reliefs. It's not enough to say 'there's plenty of clearance' - you need to record what it is. This needs to be done by turning the engine over 2 revolutions by hand, with the cam belt fitted, before final bolting the head down. Plasticine is an ideal material, and it helps to spray the valves with silicon rubber lubricant to prevent them picking up the clay.
Note that the valve positions relative to the valves are not symmetrical on pistons 1 & 4 on the 84mm bore (pre reversed port head) 8v TC. Plus the inlet valve will always be closer to the piston during its cycle than the inlet cam. The more that’s machined off block or head (or if the pistons are run proud of the block face), the less radial clearance you’ll get. On the 80mm bore (124 type 1438/1608) they are symmetrical and also all the 16v units incl 131/037 Gp4 and Integrale/Tipo heads. Ensure 80-100 thou” vertical piston-valve clearance (measured diagonally - in the plane of the valve axis), and 60 thou radially – from the valve circumference to the wall of the valve relief. How much additional clearance beyond valve full lift you allow in the vertical plane between valve and piston depends on your confidence in the valve springs. Radial clearance is affected by piston - bore clearances and guide wear.
Some comp cams have as much as 5.5mm lift at tdc (on the overlap) but cams with 3.5 mm or less lift at tdc and can often be fitted without the need for deeper valve reliefs.
Don’t forget that in the first 20 or so deg after tdc on the inlet stroke the inlet valve tries to overtake the piston, so to be on the ‘safe side’ don’t base your estimate of valve relief depth purely on the lift at tdc – the valve does move closer to the relief. It's no good just dropping the valve thru the guide onto the piston at tdc and saying 'OK, I've got 4mm vertical clearance', for one thing it's going to be a lot closer in the true cycle, and for another it doesn't tell you the radial clearance. As many engines bend or break their valves from low radial clearance as any other cause. Generally closest proximity is around 15-18 deg. If you are contemplating swinging the cam timing on the dyno it is imperative that you ‘map’ the valve lift around tdc, eg clearance from piston at 110/108/106/104/102 deg etc.
It's worth mentioning that if you think that the piston valve reliefs (cutouts) might need machining to complete the build, and BEFORE you build the head up, use an old valve stem ground to a sharp point as a punch to put down thru the valve guide to mark the valve centres on the pistons. The pistons must be held in the centre of the bores by packing them with thin card, otherwise the slop between the piston and bore will totally upset the valve relief machining. This can later be used for flycutting the valve reliefs to make them deeper or wider. Also make sure, that when you offer up the head to so this marking-out that the gasket and gasket locating dowels are in place.
Lubrication and running
Oil the cam and cam tower (or box) bearing housings and rear thrust faces – front and back - at the build stage. The biggest cause of cam lobe damage is dry-scuff or low-speed running after start up. Damage can be caused to the cam journals especially at the front end if the oilways in the block or head are contaminated, this will cause scoring to the housing and cam - and may cause even a new cam seal to leak.
Springs and valve-valve proximity
GC cams should always be used with GC triple valve springs. A separate data sheet is available on request from guy.croft@btconnect.com
You must check that the springs – whatever you decide to use – have a minimum of 2mm between closest coils at full lift. You must also make sure that:
a. The bucket does not bottom-out in its bore at high lift (16v heads)
b. The bucket does not hit the vale stem seal
c. The valves don’t hit each other during the cycle – you must have 1mm minimum valve-valve. This mainly affects big valve conversions on the 8v TC. To check this you need to build up the head and turn it over, and examine how close they get as the inlet is opening and the ex closing. GCRE use a dummy cambelt with adjustable camwheels to do this and photos are available on request.
Old cams re-used:
Fill the cam boxes with engine oil just before cranking so that the cam lobes are not spun dry. Moly grease is also a good lubricant to smear on the cam lobes but don’t use on deep-drilled or cross-drilled cams or if you are going to leave the engine standing for months – it dries out.
New cams:
You must use a good quality special cam lubricant (most cam manufacturers sell it) and pour it over the cam lobes just prior to cranking and start (cam lube will typically be a zinc dithiophosphate compound)
All cams:
Fill all the oil system accessories, filter, lines, cooler etc and crank up oil pressure on the starter with the plugs out with the cam box covers off and make sure oil is pumping into the valve train before starting the engine. It should prime up in 3 bursts of 7-10 sec cranking and in not more than 20 seconds overall. More than that and it's never going to get oil pressure. If the engine has been standing for a long time (months) you may have to prime the oil pump by removing the filter housing and injecting oil down to the pump.
With new cams it is imperative to run the engine at 2000-2500 rpm for 10 minutes to allow the cams to bed in - before allowing the engine to return to idle (750-850 rpm). Obviously timing and fuel system have to be very well set statically to permit this without overheating or stalling/flooding the engine.
Remember that the cam boxes on the TC will empty completely if the car is driven up a ramp onto a truck or trailed on the way to a race, so they will start bone-dry and wipe out the cams, whether they are cast iron or steel. Not good. Refill them!
Cam timing figures – what they mean
Typical competition cam example:
Quoted timing 40/80 80/40. These degree figures are crank degrees and mean the following:
Inlet opens 40 crank deg before tdc and closes 80 after bdc
Ex opens 80 crank deg before bdc and closes 40 after tdc
Overlap is sum of 40 + 40 = 80 crank degrees
Duration of both cams is 40 + 80 + 180 = 300 crank deg
Full lift (FL) is at (300/2) – 40 = 110 crank deg.
Thus inlet FL is 110 deg after tdc, ex is full lift 110 deg before tdc.
All cams I know of for the TC are symmetrical (same shape of open and closure flanks) and this maths can be used on any of them.
Common TC timing and full lift posn
131 1600 & 2 liter 5/53 53/5 (114 deg)
105 TC 10/48 53/5 (109/114 deg)
130TC 7/51 51/8 (112/111.5 deg)
Lancia Beta 2 liter 13/45 49/9 (106/110 deg)
Lancia Vx 13/39 37/3 (103/107 deg)
(Incidentally the true durations of the TC cams are longer, these figures are quoted with an industry standard wide running clearance which assumes no flow at very low lifts).
Don't blame cams from a reputable supplier if you cannot get the power you want
The performance (area under the torque curve) of an engine, ignoring mechanical losses, depends how well the whole spec is integrated. The camshaft is just an opening device. Here are some of the main parameters that determine power:
- Exhaust port and manifold length, diameter and manifold configuration (4-1 or 4-2-1)
- Inlet port and manifold length, diameter and rampipe length
- Head airflow inlet and exhaust – encompassing valve size and discharge coefficient, and port shape and size, combustion chamber shrouding
- Cam profile (lift by degrees) and camshaft timing (ie: FL posn)
- Bore and stroke
- Compression ratio
- Ex silencer back pressure
- Fuel system – especially carb/throttle body and choke size. Generally speaking the more powerful the engine the bigger these will be although on supercharged engines it is necessary to reduce choke size with comp cams.
As a general rule you can set FL of inlet and exhaust cams anywhere between 100 and 113 degrees. Inlet and ex FL do not need to be the same. The smaller the lobe centreline angle (LCA: sum of inlet and ex FL posn) the better the top-end response is going to be ie: flat power curve.
The cam timing will define the torque characteristic and altering it from any stated spec is not necessarily be a bad thing, but dyno development is needed to optimise it. It is not necessary to run like-for-like inlet and ex cams, the inlet cam can run higher lift or longer duration than the exhaust cam, indeed with supercharged or turbo engines it’s a bad thing to run the same cam inlet and ex. Blown engines should always have less lift and duration on the ex than inlet. A 16v Integrale for example, depending on boost, can develop well over 450bhp/400 lbf ft with as little as 11mm inlet lift, 8mm exhaust.
Proven GCRE 8V TC cam mix/combos:
4A or 5A inlet with 3D ex
3D inlet with 3A ex
3A inlet with 2B or OE standard ex
06_HSR 16v valve centres.jpg (107.77 KiB) Viewed 435156 times
05_HSR 16v head on.jpg (444.22 KiB) Viewed 435185 times
04_HSR 16v piston packed.jpg (430 KiB) Viewed 435112 times
A decent valve lapping tool is a handy way to lower the piston, rod, bearing assembly onto the bearing. No rings are fitted at this stage.
03_offering up piston.jpg (110.8 KiB) Viewed 434898 times
Anything that fits the guide snugly and has a needle point will do, old valve guide, capscrew like this. You just want a small mark - otherwise the machinist will never find true centre.
U must have the head/gasket locating dowels in place when marking the valve relief centres, check it all fits properly before starting. Use a couple of head bolts to fix it.
01_HSR 16v measusring LATDC.jpg (108.78 KiB) Viewed 434858 times
After machining the VRs put some Plasticine (a superb modelling clay) in them, build up the motor, turn over twice and examine the imprint of the valves. If the dome to head clearance is suspect, check that too.
HC 8vTC pistons dry-build_01.JPG (22.83 KiB) Viewed 434426 times
Initial clearance check valve to valve on a big valve 8v TC Fiat head, inlet valve is locked at tdc lift posn (appr 5mm from seat) and ex valve taken thru lift cycle. Need 1mm between valves.
AL 8V TC checking for valve clash.JPG (143.83 KiB) Viewed 433500 times
testing clearances on a new GC piston, this time for the 8v Integrale, using Plasticine.
D21 009.jpg (114.65 KiB) Viewed 419010 times
Locked
